I’ve always been a bit of a tinkerer when it comes to home automation, and recently, I decided to set up an automation to keep an eye on the humidity levels in my bedroom. It’s been a fascinating process, and I wanted to share my experience with you all!
Initially, I was a bit overwhelmed by the number of sensors and automations available. I stumbled upon a guide that suggested using a binary sensor combined with a notification system. That’s when I decided to give it a try. I configured a binary sensor to monitor humidity levels and set up a notification system to alert me if the levels went above a certain threshold. Here’s a snippet of my configuration:
yaml
binary_sensor:
- platform: template
sensors:
Schlafzimmer_Feuchtigkeit:
value_template: ‘{{ states.sensor.humidity Schlafzimmer.state | int > 60 }}’
friendly_name: ’ Schlafzimmer Feuchtigkeit’
alert:
name: ‘The bedroom humidity is too high!’
entity_id: binary_sensor.Schlafzimmer_Feuchtigkeit
repeat: 60
notifiers:
- my_telegram_notifier
After setting it up, I noticed something peculiar—every time the automation triggered, I received notifications every single second! It was quite frustrating, to say the least. I quickly realized that the repeat parameter wasn’t the best fit for my needs. After some research, I discovered that using a throttle condition or adjusting the logic to prevent rapid-fire notifications would be a better approach.
I modified my configuration to include a delay between notifications, ensuring that I wouldn’t be bombarded with alerts. Here’s the updated version:
yaml
alert:
repeat: 300
notifiers:
This change made a world of difference! Now, I receive a notification every 5 minutes instead of every second, which is much more manageable. It’s a small tweak, but it makes a big difference in terms of usability.
Reflecting on this experience, I realize how important it is to test and tweak automations after initial setup. What might seem like a minor detail can have a significant impact on how smoothly the system runs. I’m now more confident in experimenting with other automations, knowing that a little trial and error can lead to a perfectly functioning setup.
If anyone has tips or tricks for optimizing automations, I’d love to hear them! Happy tinkering! ![]()
