Hey everyone, I wanted to share an exciting project I’ve been working on to integrate weather data into my smart home setup. It’s been a fantastic learning experience and I’m thrilled with the results!
I’ve always been interested in automating my heating system based on outdoor conditions, so I decided to dive into using Node-RED and my CCU controller to fetch and process weather data from OpenWeatherMap. The goal was to create a script that would not only pull real-time weather information but also prepare it in a way that’s useful for my home’s heating system.
The process started with setting up a Node-RED flow to connect to OpenWeatherMap’s API. I had to figure out how to structure the API requests and parse the JSON responses. It was a bit challenging at first, but the Node-RED community has some great tutorials that really helped me out. Once I had the data flowing, I needed to transform it into something my CCU could understand and use effectively.
I ended up creating a CCU script that takes the raw weather data, processes it to calculate average, minimum, and maximum temperatures over the next 24 and 48 hours, and then stores these values in system variables. This allows my heating system to adjust based on expected temperature changes, which is especially useful during the colder months.
One of the hurdles I encountered was ensuring the script ran reliably without blocking other processes. I set it to run every 20 minutes, which seems to strike a good balance between freshness of data and system performance. I also had to make sure the API key was correctly implemented and securely stored, which was a good reminder of the importance of handling credentials properly.
Seeing this project come together has been incredibly rewarding. It’s not just about the technical accomplishment; it’s about how this integration can make my home more efficient and comfortable. I’m now looking into expanding this setup to include other weather-related automations, like adjusting window blinds based on sunlight or wind conditions.
If anyone has similar projects or tips on improving this setup, I’d love to hear about them! It’s amazing how a little bit of coding and creativity can enhance our smart home experiences. Happy automating everyone! ![]()
