Smart Blinds Automation Setup and Tips
I’ve recently set up an automation system for my smart blinds using Home Assistant, and I’d love to share my experience and some tips for anyone looking to do the same! :sun_with_face:
My Setup:
I use Fibaro Roller Shutter 3 controllers paired with my blinds. The goal was to automate their operation based on the sun’s position to maximize natural light while maintaining privacy and energy efficiency.
How I Did It:
  1. Integration with SmartWeather: I connected my setup to the SmartWeather Station Tile to get real-time illumination data. This helps in determining when the blinds should open or close based on sunlight levels.
  2. Time-Based Automation: I programmed the blinds to partially close between 7:30 AM and 11:00 AM when the sun is at its brightest. This reduces glare without blocking too much light.
  3. LUX Sensor Integration: For more precise control, I added a LUX sensor to adjust the blinds dynamically based on indoor light levels. This ensures optimal lighting conditions throughout the day.
Challenges Faced:
One issue I encountered was getting the automation to trigger correctly when combining time and illumination conditions. Initially, the system only responded to one condition at a time. After some research and tweaking, I realized the importance of using logical AND conditions to ensure both time and light levels were met before triggering the blinds.
Tips for Others:
  • Start Simple: Begin with basic time-based automation and gradually introduce sensors for more complex setups.
  • Test Thoroughly: Make small adjustments and test each part of the system before full implementation to catch any issues early.
  • Use Scenes: Create scenes for different times of the day or lighting conditions to simplify management.
Questions for the Community:
Has anyone successfully integrated multiple sensors for even more precise control? I’d love to hear about your setups and any tips you might have!
Happy automating! :rocket:
