Hey everyone! I wanted to share a fun little problem I solved with my Blink outdoor camera. You know how it’s supposed to turn on the lights when someone walks by? Well, mine stopped working out of the blue. The camera itself was still working fine, and the battery was charged, so I was a bit puzzled.
At first, I thought maybe it was the internet connection. I mean, Blink cameras rely on that, right? But after checking, the connection was solid. I even tried resetting the camera, but that didn’t do anything. Hmm, maybe it was the motion sensor? I decided to test it by walking right in front of the camera. The sensor did trigger, but the lights just wouldn’t come on.
I started digging into the Blink app settings. I noticed there was an option to adjust the sensitivity of the motion detection. Maybe it was too sensitive or not sensitive enough? I played around with the settings, but that still didn’t fix the issue.
Then I remembered that Blink cameras have a feature where you can manually test the lights. I tried that, and guess what? The lights worked perfectly when I triggered them manually. That meant the issue wasn’t with the lights themselves but with the automatic trigger.
I decided to reach out to Blink’s customer support. After a bit of back and forth, they mentioned that sometimes the firmware can cause issues. They walked me through updating the firmware, and voilà! The lights started working again.
It was such a relief to get it fixed. I guess sometimes the simplest solutions are the ones you overlook. I hope this little story helps someone else who’s having the same issue. If you’ve got any questions or tips, feel free to drop them below! ![]()
