So currently have a hive system, which is a thermostat, remote relay, and hub. The system has worked well for 5+ years to be honest, but i would like to migrate to just 1 or 2 eco systems overall. i have the M3 hub, so looking at the w100, im guessing this can control a t1 relay? but how easy is it to set schedules like i do in the hive, i.e. 19 degs between 6:45 and 8am, then 8am → down to 17 degs
Hello, I have the following control algorithm.
Methods for controlling room temperature using Aqara devices.
I make a number of automations depending on the time. At any moment I can choose the necessary mode when I take the house for security.
Don’t be fooled by the buttons on the W100 making it suitable as a thermostat, it is not. It’s just a temperature sensor with a large screen that can remote control certain other devices.
Don’t know if you’re using Home Assistant, but I have my Hive thermostat & receiver working in it without the Hive Hub, just through Zigbee2MQTT.
