I’ve recently started exploring smart lighting solutions and came across this fantastic blueprint for a smart dimmer. It’s been a game-changer for controlling my lights with a button, and I thought I’d share my experience and some tips for anyone looking to set this up.The blueprint allows you to use any button to turn on/off and dim a group of lights, which is perfect for those who want a more hands-on approach to lighting control. I’ve been using it with my Zigbee lights, and it works seamlessly. The dimming algorithms are well thought out, and the fact that it supports both timestamp-based and Zigbee Light Link standards makes it versatile for different setups.One thing I found a bit tricky at first was configuring the dimming mode. I initially tried the Timestamp algorithm but noticed some instability in the brightness levels when releasing the button. After some research and reaching out to the community, I switched to the ZHA ZLL algorithm, which provided much smoother transitions and more accurate brightness levels. This was a great learning experience, and I appreciate the detailed notes in the blueprint that helped me troubleshoot.For anyone looking to integrate this into their setup, I’d recommend starting with a single light group to test the waters. Once you’re comfortable, you can expand to multiple groups. Also, make sure to check the supported blueprints for remotes mentioned in the original post; they’re a great resource if you’re using specific devices like the IKEA E1743 or Xiaomi WXKG01LM.I’d also love to hear from others who’ve tried this blueprint. Have you encountered any unique challenges or found innovative ways to use it? Let’s keep the discussion going and help each other make the most of this fantastic tool!
