Smart Dimmer Switch Experience and Tips
I’ve always been fascinated by the idea of smart dimmer switches, so when I decided to upgrade my lighting system, I knew exactly where to start. After doing some research, I went with the GE/Jasco Smart dimmer switch from Lowes, which is designed to work seamlessly with my Iris system. The installation process was straightforward, especially since I opted for models that require a neutral wire, which I knew was essential for my setup with low load LEDs.
My first installation was a breeze. I installed it on three CREE floodlights, and it worked perfectly right out of the box—on, off, and dimming as expected. It was such a relief to see it function so smoothly, giving me the confidence to proceed with more installations throughout my home. However, as I continued, I ran into some unexpected issues. Some of the dimmer switches only functioned as on/off switches, even though they were correctly wired with all four connections: line, load, neutral, and ground. This was perplexing, especially since the manufacturer suggested potential issues with grounding or electrical noise.
After consulting with my electrician, who confirmed that the grounding was properly done, I started exploring other possibilities. I reached out to Jasco for support, and they mentioned that there might be electrical noise interfering with the dimmers. While I haven’t fully resolved this issue yet, I’ve learned a valuable lesson about the importance of checking for potential electrical interference before installation. For older homes without neutral or ground wires, this can be particularly challenging, but it’s worth the effort to ensure your smart devices work as intended.
If you’re considering installing smart dimmer switches, here are a few tips I’ve gathered along the way:
  • Always check the wiring requirements of your dimmer switch and ensure your home’s electrical setup can accommodate them.
  • If you encounter issues, don’t hesitate to reach out to the manufacturer for guidance.
  • Consider testing one switch first to ensure compatibility with your existing setup before committing to multiple installations.
Overall, my experience with the GE/Jasco Smart dimmer switches has been mostly positive. They’ve added a touch of elegance and functionality to my home, and I’m excited to continue expanding my smart lighting system. If you’re on the fence about making the switch, I’d highly recommend giving it a try—you might be surprised at how much it enhances your daily life!
