Would you have a solution where I want a lock that can not be open from the inside just by turning the knob. The situation is that I have a door going to the backyard so I need the security to get in but the same security so a child can not get out without a code so he does not have access to the pool.
Thnank you
Benoit
Thank you for reaching out to us with your needs. Currently, we don’t have such a lock, but we plan to release one that may meets your needs by the end of this year.
Wow, I’m excited for it!
@bgirard1969 For your situation, the Aqara Smart Door Lock K100 could be a potential solution. It features an “Inside Handle Lock Switch” designed to prevent undesirable unlocking from the inside. When this function is enabled, the door can only be opened from the outside, which helps avoid scenarios where a child might accidentally open the door to the backyard.
Additionally, the K100 has a Night Latch Mode. When activated, the door cannot be unlocked from outdoors in Digital Mode, and in Smart mode, only the administrator’s password, fingerprint, or NFC can unlock it. While this mode focuses more on restricting outdoor access, the “Inside Handle Lock Switch” directly addresses your need to prevent indoor unlocking via the knob.
Hope this helps! If you have more questions or want to share further details, feel free to ask—other community members might also have useful insights to contribute.
