Hi everyone! I wanted to share my recent project to make my traditional doorbell smart. It’s been a fun DIY challenge that I think others might find interesting or helpful. I’ve been inspired by some of the clever solutions I’ve seen in this community, so I wanted to give back by sharing my experience.
The Goal:
I wanted to turn my existing doorbell into a smart system that could notify me via MQTT when someone presses the bell. Additionally, I wanted the ability to disable the bell sound remotely because my dogs get overly excited when the doorbell rings. This was a practical solution to a common problem!
The Setup:
I used a NodeMCU, a few resistors, a transistor, an LED, and a 5V relay module. The doorbell transformer and bell were kept as they were, making this a cost-effective solution. The NodeMCU handles the MQTT publish when the doorbell rings and controls the relay to disable the bell sound when needed.
The Process:
- Circuit Design: I modified the existing button to trigger the NodeMCU. The circuit was designed to ensure the NodeMCU could safely control the relay without damaging the components.
- MQTT Integration: I set up the NodeMCU to publish to a specific MQTT topic whenever the doorbell is pressed. This allows me to integrate the system with my existing smart home ecosystem.
- Disabling the Bell: The relay is used to disable the bell sound. When activated, it prevents the bell from ringing, which has been a lifesaver during deliveries or when I’m trying to keep the house quiet.
Challenges and Solutions:
- Relay Noise: Initially, there was some noise from the relay when it activated. I solved this by using a higher-quality relay and adding a flyback diode to suppress voltage spikes.
- Battery Life: Since the system is powered by the doorbell transformer, I didn’t have to worry about battery life, which was a relief.
Unexpected Benefits:
One of the most rewarding parts of this project was seeing how it improved my dogs’ behavior. By being able to disable the bell sound remotely, I could train them to associate the doorbell with positive experiences rather than just excitement. It’s been a great way to reinforce good behavior!
Tips for Others:
- Start Simple: Begin with a basic circuit to ensure everything works before adding more complexity.
- Testing: Test each component individually before integrating them. This helps identify issues early on.
- Documentation: Keep detailed notes of your wiring and code. It makes troubleshooting much easier if something goes wrong.
Looking Ahead:
I’m already thinking about ways to expand this system. Maybe adding different tones for different doorbell presses or integrating it with my security camera for notifications. The possibilities are endless!
I’d love to hear if anyone else has tackled a similar project or has tips to share. Happy tinkering! ![]()
