Smart Garage Door Automation: Proximity-Based Control
I recently came across a fantastic way to automate my garage door using my Linear Go Control system. The idea is to ensure the garage door only opens when one of our phones is near the house, preventing accidental openings. While I initially thought of using Stringify, I’ve heard it’s no longer an option, and IFTTT doesn’t offer the flexibility I need for conditional triggers.
After some research, I discovered the potential of using location-based automation tools like Location Automator or integrating with Apple Shortcuts for an iPhone-centric solution. The concept involves setting up a geofence around my home—when my phone enters this zone, it triggers the garage door to open.
Here’s how I plan to implement it:
  1. Setup Geofencing: Use an app to create a virtual boundary around my home.
  2. Integrate with Smart Home Hub: Connect the app to my Linear Go Control system via the smart home hub.
  3. Test and Refine: Ensure the system works seamlessly and adjust the geofence radius as needed.
This approach not only solves the problem but also adds a layer of security by ensuring the garage door only opens when I’m nearby. I’d love to hear if others have similar setups or any tips to make this even more efficient!
Pro Tip: If you’re using an Android device, apps like Tasker or MacroDroid can achieve similar results with custom scripts. Let me know if you’d like help setting this up!
