Hello everyone,
I wanted to share my recent experience setting up a smart garage door automation system. It’s been a fantastic addition to my home, and I thought I’d walk through the process in case anyone else is looking to do something similar.
First, my goal was to create a seamless ‘welcome home’ experience. I wanted my garage door to trigger a series of actions as I arrive, such as turning off the alarm, unlocking the door, and adjusting the lights. The scene works beautifully, but I encountered a small hiccup along the way.
Initially, I set up a basic automation that would trigger whenever I opened the garage door. However, I quickly realized that this setup wasn’t perfect—it would activate regardless of the alarm’s status. I only wanted the scene to run when the alarm was armed, not every time the garage door opened.
This led me to dive into some coding within the Luup portion of my scene. I knew it was a simple If-Then statement, but getting the syntax right was a bit tricky. After some research and trial and error, I managed to get it working. Here’s the code I ended up using:
lua
local alarmstatus = luup.variable_get(“urn:micasaverde-com:serviceId:AlarmPartition2”, “ArmMode”, 94)
if alarmstatus == “Armed” then
return true
else
return false
end
This code checks the alarm’s status and ensures the scene only runs when it’s armed. It’s been a game-changer for me!
I’d like to thank the community for their invaluable help and resources. If you’re looking to set up something similar, I recommend starting with the basics and gradually adding layers of automation as you become more comfortable. It’s a rewarding process, and the result is truly worth the effort.
If anyone has questions or needs advice, feel free to reach out. Happy automating! ![]()
Best regards,
