Hey everyone! I’ve been diving into the world of smart home automation lately, and I wanted to share a fun project I’ve been working on. It’s all about integrating motion and temperature sensors to create a more comfortable and energy-efficient home environment.
My Goal
I wanted to set up a system where I could monitor the temperature of different rooms in my house and also control heating based on motion. The idea is simple: when someone enters a room, the heater turns on, and after 30 minutes of no movement, it turns off automatically. This should help save energy while keeping the house cozy.
The Setup
I decided to use a LINEAR WAPIRZ-1 motion sensor with an integrated temperature sensor. This device not only detects motion but also monitors the ambient temperature, which is perfect for my needs. I paired it with a Vera UI7 hub to handle the automation.
The Challenge
At first, I was a bit confused because the Vera only recognized the motion sensor part of the LINEAR device. The temperature sensor wasn’t showing up, and I wasn’t sure how to access that data. After some research and trial and error, I discovered that I needed to use a Luup code to extract the temperature readings. It was a bit tricky, but I managed to figure it out!
The Solution
Here’s what I did:
- I wrote a simple Luup code to pull temperature data from the LINEAR sensor. This allows me to monitor the temperature in real-time on my smartphone.
- I set up an automation rule in Vera to turn on the heater when motion is detected.
- I added a delay of 30 minutes, so if no further motion is detected, the heater turns off automatically.
The Results
This setup has been working beautifully! I can now check the temperature of each room from my phone, and the heater only runs when someone is actually in the room. It’s been a great way to save on heating costs while still maintaining comfort.
Lessons Learned
- Don’t be afraid to dive into the coding side of things. It can be intimidating at first, but there are plenty of resources and communities like this one to help you out.
- Motion sensors are incredibly versatile. They can be used for so much more than just security—they’re great for energy management too!
- Temperature sensors are a fantastic addition to any smart home setup. They add another layer of control and efficiency.
I’m really happy with how this project turned out. It’s given me a deeper understanding of how different smart home devices can work together to create a more efficient and comfortable living space. I’d encourage anyone who’s curious about automation to give it a try—start small, and build from there!
If anyone has questions or wants to share their own projects, feel free to reach out. I’d love to hear what you’re working on!
Cheers,
