I recently embarked on an exciting smart home automation project, and I wanted to share my experience with the community. My goal was to create a system that would notify me when my cat’s litter box needed cleaning, and it turned out to be a fascinating learning journey. Here’s how I approached it:
The Problem
Keeping track of the litter box has always been a bit of a hassle. I wanted a way to monitor its status without constantly checking it manually. Plus, I wanted the system to notify me only when it was truly necessary, considering my daily routines and sleep schedule.
The Solution
I decided to use a combination of motion and contact sensors, a smart light bulb, and a Shelly 1 relay. The setup involves detecting motion near the litter box and monitoring when the lid is opened. Here’s a breakdown of the components:
- Aqara Zigbee Motion Sensor: Placed under the sink to detect movement near the litter box.
- Sonoff Zigbee Contact Sensor: Attached to the litter box lid to detect when it’s opened.
- Feit Electric RGBW Bulb: Controlled via Tuya Local integration to indicate the status with color changes.
- Shelly 1 Relay: Used to maintain normal functionality of the light switch while integrating it into the automation.
The Automations
I created several automations to handle different scenarios:
Tracking Motion and Lid Openings: This automation detects motion near the litter box and turns on a helper boolean entity. It also turns off the boolean when the lid is opened, indicating that the litter box has been cleaned.
Light Control: The light bulb changes color based on the helper boolean’s status. Red indicates the litter box needs cleaning, green means it’s clean, and white or off is the default state.
Notification System: Notifications are sent only when I’m home and not asleep. They include actionable buttons to mark the litter box as cleaned or set a reminder to clean it later.
The Results
This system has been running smoothly for several weeks now. It’s incredibly satisfying to see how all these components work together seamlessly. The motion sensor has been reliable, and the contact sensor accurately detects when the lid is opened. The light color changes provide a clear visual cue, and the notifications are well-timed and actionable.
Tips and Tricks
- Helper Entities: Using helper entities like input_boolean can simplify complex automation logic. They act as middlemen, allowing you to control notifications and statuses without overwhelming the system.
- Customizable Notifications: Actionable notifications save time by letting you respond directly from your phone, whether you’re at home or away.
- Local Integration: Using local integrations like Tuya Local ensures that your system remains responsive even if your internet connection is unstable.
This project has been a fantastic way to dive deeper into smart home automation. It’s not just about solving a problem; it’s about creating a system that integrates seamlessly with your lifestyle. I’m already brainstorming my next project, but for now, I’m thrilled with how this turned out!
If anyone has questions or suggestions about this setup, feel free to reach out. I’d love to hear how others are tackling similar challenges!
