Smart Home Automation Flow Setup Tips
Hey everyone, I wanted to share my experience setting up a smart home automation flow. I recently tried creating a flow where my lights turn on when someone enters the room and turn off when they leave. It sounds simple, but I ran into an issue where the lights would turn on but wouldn’t turn off again. After some research, I realized the problem was with the trigger conditions. Using ‘ALL’ instead of ‘ANY’ was causing the flow to get stuck. I had to tweak the settings a few times before it worked smoothly. :blush:
For those of you who are new to this, I highly recommend starting with simple flows and testing each component individually before combining them. It might seem tedious at first, but it saves a lot of frustration in the long run. Plus, there are some great resources and tutorials in the forums that can help you troubleshoot common issues.
I’d also love to hear about your automation setup experiences! What’s been your biggest challenge so far, and how did you overcome it? Did you have any funny or unexpected results while testing your flows? Let’s share our stories and tips below! :rocket:
