Hello everyone, I’m thrilled to share my recent experiences with setting up smart home automation using thermostats and window sensors. My goal was to create a seamless heating system that adapts to my daily routine and ensures energy efficiency. Here’s how it went:
Thermostat Setup
I started by installing two SONOFF TRVZB thermostats in my living room. These devices promised easy integration with my Zigbee network, and I was excited to see how they’d perform. However, I encountered some unexpected challenges. Despite identical configurations, one of the thermostats failed to respond to temperature adjustments, leaving me puzzled. I discovered that the local temperature calibration settings varied drastically between devices, which might be the culprit. I’m still exploring how to standardize these settings across all my thermostats.
Window Sensors and Automation
Next, I added window sensors to enhance my system’s functionality. The idea was to prevent heating when windows are open, which should save energy. I set up automations where the thermostat would disable heating if a window was detected as open. This worked perfectly in my other rooms, but in the living room, the system seemed unresponsive. I’m curious if others have faced similar issues and how they resolved them.
Unexpected Insights
One surprising discovery was the impact of external temperature sensors. I realized that accurate outdoor temperature readings are crucial for efficient heating. Without them, my system couldn’t adjust properly, leading to inconsistent heating performance. I’m now considering how to integrate more reliable outdoor sensors to improve this aspect.
Seeking Advice
I’d love to hear from the community on how they handle temperature calibration and ensure consistent performance across multiple thermostats. Have you encountered similar issues with Zigbee devices? How did you troubleshoot them? Your insights would be invaluable as I continue refining my setup.
Thank you for reading, and I look forward to your feedback and suggestions!
