Hey everyone, I wanted to share a success story about my smart home journey and how I managed to solve a small but annoying problem in my bathroom. I hope this might help someone else out there!
So, the issue was with the bathroom lights. I have a multi-purpose sensor on the door, and while it works well, the timing was never quite right. Sometimes I’d be in there longer, and the lights would turn off too early, or I’d leave and forget to turn them off. It was frustrating, but I knew there had to be a smarter way to handle it.
After some research and tinkering, I figured out a way to make the lights turn off only after the door closes the second time. Here’s how I did it:
- Setup: I used the multi-purpose sensor on the bathroom door. The sensor detects when the door is opened or closed.
- Automation Rule: I created a rule where the light turns on when the door opens and stays on when it closes. But here’s the trick: if the door opens again and then closes, the light turns off immediately.
This setup has been a game-changer! No more lights staying on unnecessarily, and no more fumbling in the dark because I forgot to turn them on. It’s such a small thing, but it makes a big difference in daily convenience.
I’m also thinking about taking this a step further. Maybe if the bathroom gets too hot (using the sensor’s thermometer feature), the lights could dim and change color to create a relaxing atmosphere. It’s a bit ambitious, but I’m excited to explore the possibilities!
If anyone has tips or suggestions on how to improve this setup or implement the temperature-based lighting idea, I’d love to hear them. Happy automating everyone! ![]()
