Smart Home Automation Success Story: 1-Hour Timer Automation
I’ve been diving into the world of smart home automation with Home Assistant, and I wanted to share a success story that might inspire others or help those facing similar challenges.
One of my main goals was to create a reliable automation for a Sonos S26 switch. The idea was simple: turn on the switch and have it automatically turn off after exactly one hour. This would be perfect for scenarios like leaving lights on for pets or security without worrying about manually turning them off.
Initially, I set up an automation using a state trigger, monitoring the switch’s state from “off” to “on”. I included a “for” condition set to 1 hour, and the action was to activate a scene that turns off the switch. It worked like a charm during initial testing, but I quickly noticed an issue. If I rebooted Home Assistant while the switch was on, the automation wouldn’t trigger, leaving the switch on indefinitely.
This problem led me on a quest to find a more reliable solution. I experimented with different automation configurations, looked into persistent states, and even considered integrating external services. After some research and trial and error, I stumbled upon a more robust approach using a combination of Home Assistant’s built-in timers and scene management.
The solution involved creating a custom automation that not only monitors the switch’s state but also ensures the timer persists through reboots. It was a bit complex, but the satisfaction of seeing it work seamlessly was worth every minute of troubleshooting.
I’d love to hear from others who have tackled similar automation challenges. What creative solutions have you implemented to ensure reliability in your smart home setup? Let’s keep the ideas flowing and help each other make our homes smarter and more efficient!
Cheers,
Jan
