I’ve always been fascinated by the idea of automating my fireplace, but it wasn’t until I switched from Wink to Hubitat that it became a reality. My wife, who’s not typically into smart home tech, was surprisingly supportive once she saw how seamless the automation could be. Here’s how I pulled it off!
The Components:
- Remotec Z-Wave Dry Contact Fixture Module: This was the backbone of the system. It allowed me to control the fireplace without any messy wiring.
- Lutron Pico Two-Button Remote: I upgraded from the old low-voltage switch to this sleek remote for a modern look and feel.
- AC Infinity Fireplace Blower: This wasn’t just about aesthetics—it added functionality by circulating heat more efficiently.
- Claro 1-Gang Decorator Wallplate: For that clean, no-screw look that matches my home’s decor.
The Setup Process:
It wasn’t all smooth sailing. I had to troubleshoot a few things, like ensuring the power outlet under the fireplace was properly connected. I also had to do some minor wiring adjustments, which, let’s be honest, wasn’t the most enjoyable part. But seeing the Remotec module connect to Hubitat on the first try made it all worth it!
Automation Features:
- Voice Control: Now I can turn the fireplace on or off with a simple Alexa command. It’s like having a personal butler!
- Temperature Triggers: I set it up so the fireplace turns on when the temperature drops below a certain threshold. Perfect for those chilly evenings!
- Timer Functionality: To prevent overheating, I programmed it to run for 45 minutes at a time. It’s a small detail that makes a big difference.
Lessons Learned:
- Plan Ahead: Measure twice, wire once. The last thing you want is to pull out the ladder again because you miscalculated.
- Quality Matters: Invest in good components. The Lutron Pico and Remotec module were worth every penny.
- Don’t Fear the Learning Curve: Hubitat’s ecosystem is powerful, but it does take some time to get the hang of it. Take it one step at a time.
Final Thoughts:
This project wasn’t just about convenience—it was about enhancing my home’s comfort and efficiency. Now, every time I sit by the fireplace, I feel a little more connected to the smart home revolution. If you’re on the fence about automating your fireplace, I say go for it—it’s a game-changer!
Happy automating everyone!
