As a new homeowner, I’ve been on a quest to automate my heating system for better efficiency and comfort. My journey began with installing smart TRVs and setting up a local calendar integration to schedule room heating. The goal was simple: have the bedroom warm up by 5:30 AM, the office ready by 9:30 AM, and the kitchen heated at specific times throughout the day. Sounds straightforward, right? But as I quickly learned, the devil is in the details.
One of the first hurdles was dealing with special characters in room names, like apostrophes in ‘Steve’s Office.’ It turns out that keyboard inconsistencies (mixing UK and Swiss layouts) were causing issues with entity names. After some trial and error, I realized I needed to standardize the naming convention by replacing apostrophes and ensuring consistent formatting across all rooms.
The next challenge was setting up the automation rules. I wanted the heating to turn on and off at specific times using a numeric helper for temperature settings. Here’s where things got tricky. I struggled with escape characters in the template syntax and faced corruption issues when saving YAML configurations for different rooms. For instance, the kitchen automation kept rendering temperature values as [object Object] instead of the desired float values from the input number helper.
After hours of troubleshooting and consulting the community forums, I found a solution. The key was properly escaping characters in the template syntax and ensuring the numeric helper values were correctly referenced. It was a moment of triumph when the system finally worked as intended, turning the heating on and off at the scheduled times with the correct temperatures.
This experience taught me the importance of attention to detail when setting up automations and the value of a supportive community. If you’re embarking on a similar project, my advice is to standardize your naming conventions early and double-check your YAML syntax for any hidden issues. Happy automating! ![]()
