After months of research and planning, I finally set up my Homematic rolladen control system, and it’s been a game-changer!
The goal was to automate my blinds for summer shading, and I wanted something reliable and energy-efficient. I explored several options, including Helligkeitssensor and Sonnensensoren, but faced challenges with placement and weatherproofing. ![]()
Eventually, I decided on the Temperatur-Differenz-Sensor HM-WDS30-OT2-SM-2. The idea was to place one sensor in direct sunlight and the other in the shade, creating a temperature difference that triggers the blinds.
It took some trial and error, especially with scripting to handle the temperature differential, but the system now works seamlessly! ![]()
Here’s what I learned:
- Placement is key: Ensure sensors are in optimal positions for consistent readings.
- Scripting can save the day: A simple script adjusted the temperature differential to avoid false triggers.
- Patience pays off: Testing different scenarios helped refine the system.
This setup not only enhances comfort but also reduces energy costs by minimizing direct sunlight during peak hours.
I’m thrilled with the results and highly recommend exploring temperature-based solutions for similar projects! ![]()
