I’ve been on a journey to create a truly connected home, and I’m thrilled to share my success story with the community. My project started with a desire to sync my RGB lighting with the music I’m listening to, and after some research and experimentation, I’ve managed to create a seamless integration using Node-RED and Alexa. I came across some fantastic resources online, including a Reddit tutorial and a Home Assistant community thread, which provided the inspiration I needed to get started. ### The Setup I’m using Node-RED connected to Home Assistant, along with an external library called Color Thief, to extract the dominant color from the album artwork of the currently playing track. Here’s a quick breakdown of how it works: 1. Node-RED Flow: I set up a flow that monitors the state of my media player (Alexa in this case). When the state changes to “playing,” it triggers a function node that fetches the album artwork URL. 2. Color Extraction: Using the Color Thief library, I extract the dominant RGB color from the album artwork. 3. Color Adjustment: To make the colors pop, I boost the saturation slightly before sending the command to my RGB bulb. 4. Automation Loop: To ensure the colors update with each new song, I implemented a loop that tracks the media duration and position, updating the RGB values only when a new track starts. ### Challenges and Solutions One of the initial hurdles was getting the URL to update between songs. I realized that the function only acted on the media player’s state, so I added a loop to track the song’s progress and update the artwork URL accordingly. This involved creating nodes to retrieve the total song duration and current position, combining them to calculate the delay before the next artwork fetch. I also considered how to handle paused states, adding a feature to either turn off the lights or set them back to a default color based on the time of day. This adds a nice touch of customization to the experience. ### Tips for Others If you’re looking to replicate this project, here are a few tips: - Libraries and Tools: Make sure to install the Color Thief library and enable it in your Node-RED settings. - Brightness Control: Experiment with different brightness levels to find the perfect balance between ambiance and visibility. - Customization: Don’t be afraid to tweak the saturation boost or add other effects to make the colors work best for your space. ### Final Thoughts This project has been a fantastic way to immerse myself in the world of smart home automation. It’s not just about the technical achievement—it’s about creating an experience that enhances my daily life. Whether I’m relaxing at home or entertaining guests, the dynamic lighting adds a special touch that’s hard to put into words. For anyone looking to take their smart home to the next level, I highly recommend exploring Node-RED and similar tools. The possibilities are truly endless, and the sense of accomplishment when you bring your vision to life is unparalleled. Happy tinkering! ![]()
