Smart Home Automation Tips and Tricks for Multiple Devices
I’ve been diving into the world of smart home automation lately and wanted to share some of my experiences and tips for those looking to integrate multiple devices into their setup. Whether you’re setting up a new system or expanding an existing one, here are a few things I’ve learned along the way.
1. Syncing Multiple Cameras Across Locations
One thing I’ve been exploring is setting up a second location with a smart camera system. I currently have a home system with a sync module and a subscription plan, but I’m curious if I need a separate sync module for a second home with just one camera. From what I’ve read, it might depend on the specific brand and their sync module capabilities. I’d love to hear if anyone has experience with this!
2. Automating Screens with Weather and Time Conditions
I’ve been working on automating my outdoor screens to open and close based on weather conditions. My goal is to have the screens open when the temperature is above 20°C and there’s sunlight, but only after the sun has been out for at least 30 minutes. This way, I avoid constant opening and closing. I’ve tried using variables and timers in my flow, but it’s a bit tricky. If anyone has a smooth way to implement this, I’d be grateful for the advice!
3. Maintaining State Through HA Restarts
Another challenge I’ve encountered is maintaining state and attributes set by an external program after a Home Assistant restart. I use an external Python script to update energy-related states, but after a restart, these values disappear. I’ve heard about using custom components or persistent storage, but I’m not entirely sure how to implement this. Any insights would be fantastic!
4. Custom RGB Color Formatting
I’ve been experimenting with setting custom RGB colors for my Nanoleaf Essentials bulbs in Rule Machine. The input box hints at a #rrbbgg format, but figuring out the exact syntax has been a bit confusing. I’ve tried several combinations, but nothing seems to work. If anyone has cracked this code, I’d appreciate a quick tip!
5. Troubleshooting Empty Cards in Custom UI
Lastly, I recently updated my custom UI and ended up with empty cards after the update. The logs mentioned a 404 error related to state-card-custom-ui-es5.html. I had to delete the entry from frontend.yaml to get the frontend back, but the cards are still empty. I’m curious if this is a common issue and if there’s a fix or workaround out there.
These are just a few of the challenges I’ve faced while setting up my smart home. I’d love to hear your experiences, tips, and tricks for overcoming similar hurdles. Let’s keep the conversation going and help each other create the smart home of our dreams! :rocket:
