Starting my smart home journey was both exciting and a bit overwhelming. After researching various devices and platforms, I decided to go with a mix of Zigbee and Wi-Fi devices to cover all my needs. Here’s a quick rundown of my setup and some tips I’ve learned along the way.
My Setup
- Smart Plugs: I use EVA Zigbee Smart Plugs for controlling my heater and other appliances. They’ve been reliable and integrate seamlessly with my Zigbee2MQTT setup.
- Motion Sensors: Aqara motion sensors have been a great addition, though I had to tweak the network settings to improve their connection stability.
- RGB LED Strip: I recently installed an RGB LED strip in my garage for a fun and functional project. It’s controlled via WLED and automatically changes colors based on garbage/recycling days.
Tips I’ve Learned
- Firmware Updates: Always keep your devices updated! I learned this the hard way when my Zigbee entities went offline after an update. Thankfully, the community forums had solutions.
- Network Stability: If you’re using Zigbee, ensure your coordinator (like RaspBee II) is in a central location to maximize range and reliability.
- Custom Automations: Don’t be afraid to dive into YAML for custom automations. It takes time, but the payoff is worth it. For example, my garbage day notifier was a fun project that combined hardware and software.
- Community Resources: The Home Assistant and Zigbee2MQTT communities are amazing. If you run into issues, chances are someone else has too and shared a solution.
A Little Story
One of my favorite moments was setting up the RGB LED strip notifier. My family now knows exactly when to put out the trash without me having to remind them. It’s these small wins that make the whole project worthwhile!
If you’re just starting out, my advice is to take it one device at a time and enjoy the learning process. Happy automating! ![]()
