I recently embarked on a project to integrate my Arduino Uno with my Raspberry Pi 5, and I must say, it’s been a rewarding journey! My goal was to transmit sensor data from my Arduino to my Raspberry Pi, which runs Home Assistant. I have several Shelly devices already integrated, but adding Arduino data was the next step in my automation quest.
Initially, I faced some challenges. I tried using the serial interface between the Arduino and Raspberry Pi, but the data wasn’t coming through as expected. After some research and experimentation, I discovered that using MQTT was the key. I set up an MQTT broker on my Raspberry Pi and configured my Arduino to publish sensor data to specific topics. Now, I can monitor my DHT22 and DS18B20 sensors directly in Home Assistant!
One thing I learned is the importance of keeping my Home Assistant add-ons updated. I encountered a few issues where the MQTT integration wasn’t behaving as described in older guides. Thankfully, the community forums and documentation were invaluable in troubleshooting these issues.
For anyone looking to integrate Arduino with Raspberry Pi, here’s a quick tip: ensure your MQTT broker is correctly configured and test the connection before integrating with Home Assistant. Also, don’t hesitate to reach out to the community if you’re stuck—there are plenty of helpful folks willing to assist!
This project has inspired me to explore even more possibilities with my smart home setup. The satisfaction of seeing everything work seamlessly is truly rewarding. If you’re considering similar integrations, I highly recommend starting small and gradually expanding your setup. Happy automating! ![]()
