Smart Home Integration Success Story: Combining Govee, ESP32, and Home Assistant
I’ve been on a journey to create a seamless smart home ecosystem, and I wanted to share my experiences and tips with the community. My setup combines Govee smart lights, an ESP32 microcontroller, and Home Assistant for automation. Here’s how it went!
The Goal
I wanted to automate my lighting system to turn on when someone enters the room. After some research, I decided to use an ESP32 with an mmWave presence sensor and integrate it into Home Assistant. The challenge was safely controlling the lights without damaging the circuit.
The Process
  1. ESP32 Setup: I connected the ESP32 to the mmWave sensor and programmed it to detect motion. The sensor communicates with Home Assistant via MQTT.
  2. Testing Safety: I used a multimeter to measure the current and voltage across the light bar’s JST-XH2Y plug. It showed 2.8 volts with no significant current draw, indicating it’s safe to short the pins with the ESP32’s GPIO.
  3. Integration with Home Assistant: I configured ESPHome to handle the GPIO control and set up an automation in Home Assistant to turn the lights on when motion is detected.
The Outcome
The system works perfectly! The lights turn on seamlessly when someone enters the room, and they stay off when the room is empty. I’m especially happy with how Govee’s smart lights integrate into this setup—they’re reliable and offer great color customization.
Tips for Others
  • Test Circuit Safety: Always measure voltage and current before shorting pins to avoid damaging your devices.
  • Use MQTT for Communication: It simplifies integrating different hardware components into Home Assistant.
  • Leverage ESPHome: It’s a fantastic tool for managing ESP32 devices and automations within Home Assistant.
Looking Ahead
I’m now exploring adding more sensors and automations, like adjusting lighting based on time of day or integrating with my soon-to-be-installed Netatmo weather station. If anyone has tips on combining these systems, I’d love to hear them!
This project has been a fantastic learning experience, and I’m excited to continue expanding my smart home setup. Thanks to the community for all the resources and support! Let me know if you have questions or want to share your own integration stories.
