Hello fellow smart home enthusiasts!
I wanted to share my recent experiences setting up my smart home, focusing on connectivity and automation. Hopefully, this will help others facing similar challenges or inspire new ideas!
1. WLAN Connection Issues & Solutions
I recently noticed that my Ematic device (EM) was experiencing frequent WLAN disconnections due to its distance from the AP. After some research, I realized adjusting the device’s orientation to align its internal antenna with the AP could improve connectivity. If anyone has tips on optimizing antenna placement or has faced similar issues, I’d love to hear your experiences!
2. AC Automation Success Story
One of my proudest achievements has been setting up an automation to control my AC based on temperature readings. Here’s the setup I used:
yaml
alias: AC
trigger:
- platform: template
value_template: >-
{{ states(‘sensor.temperature_and_humidity_sensor_temperature’) | float > 28 }}
id: “On” - platform: template
value_template: >-
{{ states(‘sensor.temperature_and_humidity_sensor_temperature’) | float < 27 }}
action: - choose:
- conditions:
- condition: trigger
sequence: - service: google_assistant_sdk.send_text_command
data:
command: “Turn on AC” - service: google_assistant_sdk.send_text_command
data:
command: “Set AC temp to 16”
- conditions:
data:
command: “Turn off AC”
- conditions:
This automation ensures my AC turns on when the temperature exceeds 28°C and turns off when it drops below 27°C. It’s been working flawlessly and has significantly improved my comfort at home!
3. Integration Challenges & Solutions
I’ve also been experimenting with integrating a Shelly 3EM energy monitor into my setup. Initially, I struggled with getting accurate readings, but after adjusting the wiring and ensuring all connections were secure, everything started working as expected. If anyone has tips on optimizing energy monitoring setups, I’d appreciate hearing them!
4. Looking Ahead
As I continue my smart home journey, I’m excited to explore more advanced automations and integrations. I’m particularly interested in enhancing my lighting setup and experimenting with more complex scenarios using Zigbee2MQTT.
If anyone has advice, success stories, or lessons learned, I’d love to hear them! Let’s continue to support and inspire each other in building smarter, more connected homes! ![]()
Best regards,
