Smart homes can sound far more complicated than they actually are.
You might have heard people talking about smart bulbs, Matter, Thread, Zigbee, hubs, routines, voice assistants and dozens of different apps. It can quickly feel like you need to be an IT expert just to turn a light on from your phone.
The good news is that you don’t.
A smart home can be as simple as being able to say, “Turn the living room lights on,” or having your heating automatically switch off when you leave the house.
The trick is choosing the right system from the beginning.
In this beginner’s guide, we’ll look at the three biggest options: Amazon Alexa, Google Home and Apple Home, and explain how they work, what you need and which one might be right for you.
So, what actually is a smart home?
At its simplest, a smart home is a collection of household devices that can be controlled automatically or remotely.
That could include:
Smart light bulbs
Smart plugs
Smart thermostats
Smart TVs
Video doorbells
Security cameras
Smart blinds
Smart speakers
Robot vacuum cleaners
Smart locks
Air purifiers and fans
Instead of controlling everything separately, you can bring compatible devices together into one system.
For example, you could have a “Good Morning” routine that turns on your bedroom lamp, opens the blinds, tells you the weather and starts your coffee machine.
Or an “I’m Leaving” routine that turns off the lights, switches off certain plugs and adjusts your heating.
That’s where platforms like Alexa, Google Home and Apple Home come in.
The three big smart home platforms
There are three main ecosystems that beginners are likely to come across:
Amazon Alexa
Alexa is Amazon’s smart home platform and is probably one of the easiest ways to get started.
You control it through the Alexa app or compatible Echo speakers and displays.
Alexa works with a huge range of smart home products, including devices from brands such as Philips Hue, Ring, TP-Link, Tapo and many others.
Its biggest advantage is compatibility.
If you’re buying a smart bulb, plug or camera, there’s a good chance it will work with Alexa.
Best for: people who want lots of choice and an easy way to control devices with their voice.
Google Home is Google’s equivalent platform.
You can manage your devices through the Google Home app and control them using Google Assistant on compatible devices.
Google’s ecosystem is particularly appealing if you’re already heavily invested in Android, Google Nest speakers, Chromecast or other Google products.
Google Home can also bring compatible third-party devices together, meaning you don’t necessarily have to buy everything from Google.
Best for: Android and Google users who want their smart home integrated with the Google ecosystem.
Apple Home
Apple Home, sometimes referred to as HomeKit, is Apple’s smart home platform.
If you use an iPhone, iPad, Apple Watch or Mac, Apple Home can feel incredibly natural.
Your smart home is managed through the Home app, and you can control compatible devices using Siri.
For example:
“Hey Siri, turn the living room lights off.”
Apple also puts a strong emphasis on privacy and security, which is one reason many Apple users prefer it.
The downside is that Apple Home historically hasn’t supported quite as many devices as Alexa or Google Home.
That gap has improved significantly with Matter, however.
Best for: people who already live in the Apple ecosystem and want everything to work together seamlessly.
But which one should I choose?
This is probably the biggest question beginners have.
The honest answer is: choose the ecosystem that fits the technology you already use.
If you have an iPhone and lots of Apple devices, Apple Home makes a lot of sense.
If you use Android and Google services heavily, Google Home is a natural choice.
If you want the widest possible selection of smart home products, Alexa is difficult to ignore.
But there’s an important development that makes this decision less intimidating.
Meet Matter
You may have seen the word Matter appearing on smart home packaging.
Matter is designed to make smart home devices work across different platforms.
In other words, instead of buying a smart bulb that only works with Alexa, you can increasingly buy a Matter-compatible bulb that can work with Alexa, Google Home or Apple Home.
That’s a big deal.
It means you don’t necessarily have to lock yourself into one manufacturer’s ecosystem.
However, there is still an important distinction between Matter and the platform itself.
Matter is essentially the common language that compatible devices can use.
Alexa, Google Home and Apple Home are the systems you use to manage those devices.
Start small. Seriously.
One of the biggest mistakes beginners make is trying to turn their entire house into a smart home overnight.
You don’t need to.
Start with something simple.
A great first smart home setup
I’d recommend starting with:
- One smart speaker or home hub
This gives you somewhere to control your devices from.
- Two or three smart bulbs
Put them in the rooms you use most.
- One or two smart plugs
These are incredibly useful for turning ordinary appliances on and off.
That’s enough to start experimenting.
You can then add more devices when you find something that would genuinely make your life easier.
Smart bulbs are probably the easiest place to start
Smart bulbs are one of the simplest smart home upgrades.
Replace your existing bulb with a compatible smart bulb and suddenly you can control it from your phone.
Depending on the bulb, you might be able to:
- Turn it on and off
- Dim it
- Change the colour
- Set schedules
- Create routines
- Control it remotely
- Control it with your voice
You could even create a routine called Movie Night that dims the lights automatically when you want to watch TV.
The important thing to remember is that the physical light switch generally needs to remain switched on for the smart bulb to stay connected.
Smart plugs are even easier
Smart plugs are brilliant because they can make an ordinary appliance smarter.
Plug the smart plug into the wall, then plug your appliance into it.
You can then control the power remotely.
They’re particularly useful for things like:
- Lamps
- Fans
- Christmas lights
- Some coffee machines
- Chargers
- Small appliances
However, there is one important limitation.
A smart plug can only control the power.
If you plug a TV into one, for example, turning the plug on doesn’t necessarily mean the TV will turn on. The appliance itself needs to be designed to start operating when power is restored.
The real magic is in routines and automations
Controlling individual devices is useful.
Automating them is where a smart home becomes genuinely useful.
Instead of saying:
“Turn the lights off.”
You can create an automation that does it for you.
For example:
Leaving Home
When you leave:
- Turn off downstairs lights
- Turn off selected smart plugs
- Adjust the heating
- Lock compatible doors
- Turn off entertainment devices
Good Morning
At 7:00am:
- Turn on bedroom lights at 20%
- Open compatible blinds
- Start the heating
- Tell you the weather
- Play your morning playlist
Good Night
When you say “Good night”:
- Turn off the lights
- Turn off the TV
- Switch off selected plugs
- Turn on hallway lighting at 10%
You don’t need to remember to do all of those things individually.
One command can do everything.
Don’t buy devices based solely on price
This is probably the most important piece of advice for anyone starting a smart home.
A £5 smart bulb might look like a bargain.
But if it requires a terrible app, constantly loses connection and doesn’t work with your chosen platform, you’ve saved yourself £10 and created a massive headache.
Before buying something, check:
Does it work with my smart home platform?
And ideally:
Does it support Matter?
Also look at whether the device requires a separate hub.
Some smart home products connect directly to your Wi-Fi.
Others use technologies such as Zigbee or Thread and require a compatible hub or controller.
You don’t necessarily need to understand the technical details to get started, but it’s worth knowing that not every smart device connects in exactly the same way.
Wi-Fi isn’t always the answer
If you start adding lots of smart devices, you might eventually notice something.
Your Wi-Fi network can become surprisingly busy.
A couple of smart bulbs aren’t going to cause a problem.
But imagine having:
- 20 smart bulbs
- 10 smart plugs
- Several cameras
- Smart speakers
- TVs
- Phones
- Tablets
- Computers
- Consoles
- Doorbells
- Sensors
Suddenly your network is doing a lot.
This is where technologies such as Thread can become useful.
Thread is a low-power wireless networking technology designed for smart home devices.
It creates a mesh network between compatible devices rather than relying entirely on your normal Wi-Fi network.
You don’t need to become an expert in Thread before buying your first smart bulb.
Just remember that Matter and Thread aren’t the same thing.
Matter is the smart home standard.
Thread is one of the networking technologies that Matter devices can use.
What about smart home hubs?
A hub or controller is essentially the middleman between your smart home devices and the platform you’re using.
Depending on your setup, you might not need a separate box at all.
For example, you may already own a device that can act as a smart home controller.
This is another reason it’s worth looking at the devices you already own before buying anything.
If you have an Apple TV, HomePod, Google Nest device or compatible Amazon Echo, for example, it may already provide some of the functionality your smart home needs.
The easiest way to manage everything
If you’re starting from scratch, I’d recommend thinking about your smart home in three layers.
Layer 1: The devices
These are the things you’re actually controlling.
Lights, plugs, heating, cameras, blinds, TVs, etc.
Layer 2: The platform
This is the system that brings everything together.
Layer 3: Automations
This is where you tell the system what should happen automatically.
“When I leave, turn everything off.”
Once you understand those three layers, smart homes become much less confusing.
Alexa vs Google Home vs Apple Home
Here’s the simple version:
Alexa Google Home Apple Home
Ease of use ![]()
Device compatibility ![]()
Apple integration ![]()
Android integration ![]()
Voice control ![]()
Privacy focus ![]()
Beginner friendly ![]()
These aren’t absolute scores, but they give you an idea of where each platform tends to shine.
My advice for a first smart home
Don’t start by trying to automate everything.
Pick one room.
The living room is usually a great place to start.
You could have:
- A smart lamp
- A smart plug
- Smart TV integration
- A smart speaker
- A few routines
Then experiment.
Create a Movie Night routine.
Create a Good Night routine.
Try controlling everything from your phone.
Try voice commands.
Once you’ve got the hang of it, move into another room.
Eventually, your smart home grows organically around the things that are actually useful to you.
And that’s the important bit.
A smart home shouldn’t make your life more complicated.
It should remove little annoyances from your everyday life.
If you have to open five different apps, remember which manufacturer made each device and troubleshoot your lights every evening, you’ve probably made things too complicated.
The best smart home is the one you barely notice.
You walk into a room and the lights come on.
You leave the house and everything switches off.
You go to bed and one command shuts everything down.
You don’t have to think about it.
That’s when you’ve done it right.
