Smart Humidity Management with Balance Ventilation
I recently faced a challenge in managing humidity in my bathroom, especially after taking showers. High humidity can lead to mold growth and a less comfortable environment, so I decided to tackle this issue head-on. Here’s how I approached it and the solution I came up with, which might be helpful for others facing similar problems.
The Problem:
After using the bathroom, humidity levels would spike, and it would take a long time for the room to dry out naturally. This was uncomfortable and potentially damaging to the bathroom’s structure over time.
The Solution:
I decided to integrate my smart home system to manage humidity more effectively. The goal was to automate the ventilation system to kick in when needed and adjust its speed based on real-time humidity levels.
Step-by-Step Setup:
  1. Hardware Setup:
    I added a smart power plug to control the balance ventilation fan. This allowed me to override the remote control settings and manage the fan’s speed directly through my smart home system.
  2. Sensor Integration:
    I connected an Aqara temperature and humidity sensor to monitor the bathroom’s environment. This sensor provides real-time data, which is crucial for the automation to work effectively.
  3. Automation Flows:
    I created several flows in my smart home system to handle different aspects of humidity management:
  • Humidity Monitoring Flow (HUM001): This flow calculates the average humidity level over time. It uses a formula to smooth out fluctuations in sensor readings, ensuring more reliable data for decision-making.
  • Limit Setting Flow (HUM002): Based on the average humidity, this flow sets a threshold for when the ventilation should stop. I added a buffer percentage to ensure the room stays comfortably dry without over-ventilating.
  • Fan Activation Flow: This flow triggers the ventilation fan on high speed when motion is detected in the bathroom, ensuring fresh air starts circulating immediately after use.
  • Fan Shutdown Flow: A timer-based flow checks every two minutes to see if the humidity has dropped below the set threshold. If it has, the fan shuts off to save energy.
  1. Testing and Fine-Tuning:
    After setting everything up, I tested the system extensively to ensure it worked as expected. I made adjustments to the buffer percentage and timer intervals based on real-world performance to optimize energy usage and comfort.
Results:
This setup has been a game-changer for my bathroom. The automation ensures that humidity levels are kept in check without requiring constant manual intervention. The fan now runs only when necessary, which is both energy-efficient and quieter overall.
Tips for Others:- Sensor Placement: Ensure your humidity sensor is placed correctly to get accurate readings. Avoid placing it too close to water sources or in areas with direct airflow.
  • Buffer Percentage: Experiment with different buffer percentages to find the sweet spot between comfort and energy efficiency.
  • Regular Maintenance: Clean your ventilation system periodically to ensure it operates effectively and doesn’t become a source of mold or odors.
If you’re dealing with humidity issues in your home, I highly recommend exploring smart automation solutions. It might seem a bit complex at first, but the benefits in terms of comfort and energy savings are well worth the effort!
Happy automating! :rocket:
