Smart Infinity Mirror Project & Integration Tips
Hey everyone! I wanted to share an exciting project I recently completed—a smart infinity mirror. It’s been a fantastic way to combine my love for DIY projects with my interest in smart home technology. Here’s how I did it and some tips for anyone looking to try something similar!
The Project
I started with a basic infinity mirror kit from Amazon. The concept is simple but stunning: two mirrors facing each other with LED lights in between create a mesmerizing effect. I decided to take it a step further by adding smart home functionality.
I used a HelTec WiFi Kit 32 to control the LED strip. This little board has been a lifesaver—it’s compact, easy to program, and supports OTA updates, which is a huge plus for future enhancements. I also integrated it with Home Assistant to control the mirror’s brightness, color, and even create custom scenes.
Setup & Challenges
The setup was mostly straightforward, but I did run into a few hiccups. Initially, I struggled with getting the LED strip to sync perfectly with the mirror’s reflections. After some trial and error, I realized the key was in the placement of the LEDs and the angle of the mirrors.
Another challenge was ensuring smooth transitions between colors. I ended up writing a small script to gradually shift between hues, which made the experience much more relaxing.
Tips for Others
  1. Plan Your Wiring: Take the time to map out where your wires will go. This will save you a lot of frustration later on.
  2. Test Early: Before sealing everything up, test your components individually to ensure everything works as expected.
  3. Use OTA Updates: If you’re using a microcontroller, enable OTA updates. It makes future upgrades a breeze!
  4. Custom Scenes: Create scenes in your smart home platform for different moods. For example, a calming blue for relaxation or a vibrant rainbow for parties.
Community Resources
If you’re interested in diving into this project, I’ve shared all my notes and code on GitHub. Feel free to check it out and contribute your own ideas!
This project has been a fantastic way to experiment with smart home tech while creating something visually stunning. I’m already brainstorming ways to expand it further—maybe adding sound or motion sensors!
A huge thank you to everyone in the community for your support and inspiration. If you have any questions or suggestions, I’d love to hear them!
Cheers, [Your Name]
