Smart Irrigation Automation and Beyond
I’ve been on a journey to automate my garden’s irrigation system using smart home technology, and it’s been both rewarding and challenging. Let me share my experiences and some tips that might help others looking to do the same.
The Setup:
I have a tent with lights that switch on at 4 AM and off at 10 PM. I wanted my water pump to run for 2 minutes every 2 hours, starting from 4:30 AM until 8:30 PM, totaling 9 cycles. Initially, I set up an automation with multiple timers, but it quickly became cumbersome. Every time I needed to adjust the schedule, I had to edit each timer individually, which was time-consuming and error-prone.
The Solution:
After some research, I found a more efficient way to handle this using a single automation with delays. Here’s how I structured it:
alias: 4x4 Automation
description: “”
trigger:
  • platform: time
    at: “04:30:00”
    condition:
    action:
  • service: switch.turn_on
    data: {}
    target:
    entity_id: switch.sonoff_1000eca7dd
  • delay: hours: 0 minutes: 2 seconds: 0 milliseconds: 0
  • service: switch.turn_off
    data: {}
    target:
  • delay: hours: 2 minutes: 0 seconds: 0 milliseconds: 0
    mode: queued
    max: 9
This setup simplifies the automation significantly. It turns the pump on at the specified time, waits 2 minutes, turns it off, waits 2 hours, and repeats. The max: 9 ensures it runs exactly 9 times, covering the entire day.
The Challenge:
One concern I had was what happens during a power outage. Would the automation lose count and reset? After some digging, I found that while the automation itself might reset, there are ways to make it more resilient. For example, using a battery-backed timer or ensuring the system has a backup power source can help maintain continuity.
Tips for Others:
  1. Start Simple: Begin with a basic automation and gradually add complexity as you become more comfortable.
  2. Test Thoroughly: Before implementing changes, test them in a controlled environment to avoid unexpected issues.
  3. Use Queued Mode: This ensures actions are executed in sequence without overlapping, which is crucial for tasks like watering.
  4. Consider Fail-Safes: Incorporate checks to prevent overwatering or other unintended consequences.
The Outcome:
This setup has been running smoothly for weeks, and I’ve noticed a significant improvement in the health of my plants. The automation takes the guesswork out of watering, allowing me to focus on other aspects of my garden.
I’m now looking to expand this system to include soil moisture sensors, which would allow the pump to activate only when needed, further optimizing water usage. If anyone has experience with integrating sensors into irrigation systems, I’d love to hear your insights!
Happy automating!
