Earlier this year, I decided to tackle my outdated sprinkler system and turn it into a smart solution. After some research, I stumbled upon a clever way to repurpose an old timer system with a relay and Webcore automation. Here’s how it went down:
The Setup
I started by wiring a relay into the existing timer system. The relay essentially acts as a smart switch, allowing me to control the sprinkler solenoids remotely. I set the timer to run every zone sequentially at 7am daily, which kept things simple for now.
The Automation
Using Webcore, I created a rule that monitors the daily rainfall and weather forecast. If the rain is below a certain threshold and the sprinklers haven’t run in the last ‘n’ days, the relay turns on, activating the sprinkler system. This setup ensures that the system only runs when necessary, saving water and reducing maintenance.
The Results
After a few weeks of testing, the system has been a game-changer! It’s been incredibly reliable, and I love the peace of mind knowing that my lawn is being taken care of without constant supervision. Plus, the ability to adjust the frequency and rain thresholds gives me full control over the system’s behavior.
Lessons Learned
- Start Simple: I kept the initial setup straightforward to avoid overwhelming myself. The timer does its thing, and the relay handles the smart logic.
- Leverage Existing Hardware: Don’t underestimate the value of older systems. With the right add-ons, they can be transformed into modern solutions.
- Automation is Key: Webcore’s flexibility made it easy to create a custom solution that fits my specific needs.
If you’re looking to upgrade your irrigation system without breaking the bank, I highly recommend exploring similar DIY solutions. The community here has been invaluable in helping me troubleshoot and refine my setup. Happy tinkering! ![]()
