Smart Irrigation System Battery Issues and Solutions
Hello everyone, I’m reaching out to share my experience with setting up an automated irrigation system using HomeMatic devices. This journey has been both challenging and rewarding, and I thought it might be helpful to document my experiences for anyone else tackling a similar project.
The Setup
I recently installed a custom-built automatic watering system, which, in theory, should run smoothly. However, I encountered some unexpected hurdles, particularly with battery-operated actuators. After some research and trial and error, I switched to using HM-LC-SW4-Ba-PCB switches, which have improved reliability. Manually triggering these switches works perfectly, but I wanted to integrate them into my Node-Red setup for MQTT and user interface control.
The Challenge
When attempting to control the system via Node-Red, I encountered a recurring ‘Device Communication’ error. This inconsistency was frustrating, especially since I had successfully integrated other devices like my blinds and numerous sensors. The system requires multiple switching actions with a 3-second delay between each, which seems to exacerbate the issue.
My Questions
  • Delays and Reliability: What are the recommended switching delays for HomeMatic (non-IP) devices to ensure consistent operation?
  • Troubleshooting: Have others experienced similar communication issues, and if so, how did they resolve them?
What I’ve Tried
I’ve experimented with adjusting the delay intervals, ranging from 2 to 5 seconds, but the results have been inconsistent. Sometimes the system works flawlessly, while other times it fails to respond altogether. I’m curious if others have encountered similar problems and how they’ve optimized their setups.
Looking for Insights
I’m hopeful that the community might have some tips or best practices for managing delays and ensuring reliable communication with HomeMatic devices. Whether it’s adjusting timing intervals, optimizing network settings, or using specific firmware versions, any advice would be greatly appreciated.
This project has been a fantastic learning experience, and I’m eager to refine it further. The ability to automate such a critical system is incredibly valuable, and resolving these communication issues would take it to the next level. I’m looking forward to hearing from those who might have faced and overcome similar challenges.
Best regards,
