Hi everyone, I wanted to share my recent project where I integrated my Rainbird irrigation system with Home Assistant. It has 9 zones, and I’ve been looking for a way to automate the watering process without needing to manually control each zone. After some research and experimentation, I came up with a solution that allows me to start all zones sequentially with the push of a button. Here’s how I did it:
Sequential Activation: I set up a button in Home Assistant that triggers a script. This script starts Zone 1 for 10 minutes, then automatically moves to Zone 2 once Zone 1 is done, and so on. There’s a small break (1-3 seconds) between each zone to ensure smooth switching.
Custom Slider Control: I added a slider for each zone, allowing me to adjust the watering time individually. This is super handy because different areas of my garden have different watering needs.
Automation Setup: I used Home Assistant’s automation feature to handle the timing and sequence. It was a bit tricky at first, but breaking it down into smaller tasks made it manageable.
Testing and Fine-Tuning: I tested the system multiple times to ensure everything works smoothly. The initial setup had a few hiccups, like zones overlapping or not starting at the right time, but adjusting the timing and break periods fixed those issues.
This setup has been a game-changer for my gardening routine. It’s now much easier to manage the irrigation without constant supervision. Plus, having the ability to customize each zone’s watering time gives me more control over my garden’s health.
If anyone has similar projects or tips for improving irrigation automation, I’d love to hear about them! ![]()
