Smart Lighting Automation: A Hands-On Solution
Hello fellow smart home enthusiasts! I wanted to share my recent journey in setting up an automated lighting system in my kitchen. While it might seem straightforward, it involved some problem-solving and creative thinking, which I’d love to walk you through.
The Challenge:
I have a mix of ZigBee-enabled lights in my kitchen, including IKEA TRÅDFRI spots. My goal was to automate them so that they turn on when someone enters the room and dim after a period of inactivity. The challenge was ensuring smooth integration with my existing setup, which includes a Philips Hue Bridge and a CCU system.
The Setup:
I decided to use the Hue Add-On by J-A-N and CuxD to import my lights into the CCU. This allowed me to create groups and scenes directly within the CCU interface. I also set up a motion sensor to detect presence and a timer to handle the dimming functionality.
The Solution:
  1. Motion Detection: The motion sensor triggers the lights to turn on if it’s dark. This is handled by a simple program that checks the sensor status and adjusts the lights accordingly.
  2. Dimming Timer: Once the lights are on, a timer starts counting down. If no motion is detected within 5 minutes, the lights dim to a lower brightness level.
  3. Night Mode: I added a night mode using a separate switch, ensuring the lights are soft and gentle in the early hours.
Lessons Learned:
  • Integration is Key: Combining different devices and protocols can be tricky, but tools like CuxD and the Hue Add-On make it manageable.
  • Timing Matters: Testing different delay settings was crucial to ensure the system doesn’t turn off too early or too late.
  • Customization: Tailoring the automation to my specific needs (like the night mode) made the system much more user-friendly.
I’d love to hear from others who have tackled similar projects or have suggestions for improvement. It’s amazing how a little bit of tweaking can make your home truly smart!
Cheers,
