Smart Lighting Automation Challenge and Solution
Hey everyone, I wanted to share a challenge I recently faced while setting up my smart lighting automation. I’m relatively new to the world of home automation and have been experimenting with integrating various devices from different brands. One of my goals was to create a seamless lighting experience that adjusts based on motion and time of day. However, I encountered an issue that took some time to resolve, and I thought I’d document it here in case others are facing similar problems.
So, the setup: I have a mix of Zigbee and Wi-Fi connected lights, along with motion sensors placed strategically around my home. I wanted the lights to dim when motion is detected and turn off after 30 seconds of inactivity. Sounds simple enough, right? But here’s where things got tricky. If the lights were already on at a higher brightness level (say, 50%), the automation wouldn’t turn them off when motion stopped. Instead, it would leave them at the same brightness level. This was frustrating because it defeated the purpose of energy-saving automation.
After some research and trial and error, I realized the issue was with how the automation rule was structured. I was using a simple if-then condition without accounting for the current brightness level of the lights. To fix this, I adjusted the rule to first check the current brightness level before deciding whether to turn the lights off. If the brightness was above a certain threshold (like 33%), the lights would remain on. If it was below, they would turn off after the 30-second delay.
Here’s how I implemented the solution:
  1. Brightness Check: I added a condition to check the current brightness level of the light. If it was above 33%, the automation would not trigger a shutdown.
  2. Dimming on Motion: When motion was detected, the lights would dim to 32% (just below the threshold) to conserve energy while still providing enough light.
  3. Timeout Logic: If no motion was detected for 30 seconds, the lights would turn off entirely, but only if they were below the brightness threshold.
This adjustment worked perfectly! The lights now behave as intended, turning off when no one is in the room but staying on if they’re already at a higher brightness level. It’s a small tweak, but it makes a big difference in terms of usability and energy efficiency.
I’d love to hear if others have encountered similar issues or have tips for optimizing automation rules. Happy automating! :rocket:
