Hey everyone! I’m thrilled to share my recent success with setting up a smart lighting automation system in my bathroom. It’s been a journey of learning and problem-solving, and I’d love to walk you through it.First, let me give you some context. I’ve been using smart home devices for a while now, but I’m still considered a newbie when it comes to more complex setups. My goal was to create an automated system that would turn on the bathroom light when someone enters, keep it on while they’re using the space, and then turn it off when they leave. Plus, I wanted this to happen only during nighttime hours to save energy.I started by installing a Wyze Bulb in the bathroom. It’s a great product with vibrant colors and smooth dimming, so I knew it would be perfect for this project. Next, I added a contact sensor to the bathroom door. The idea was to use these two devices together to create a seamless automation experience.I envisioned the following scenario:1. The light turns on when the door is opened after sunset.2. It stays on as long as the door remains open or closed (indicating occupancy).3. It turns off automatically once the door is closed, ensuring energy efficiency.4. The system doesn’t activate during daylight hours to avoid unnecessary usage.At first, setting this up was a bit overwhelming. I had to dive into the automation rules in my smart home app and tweak them several times before everything worked as intended. I encountered a few hiccups along the way, like the light occasionally turning on during the day or not responding to the door sensor accurately. But with some research and trial and error, I figured out the right configuration.One of the key lessons I learned was the importance of timing and conditions in automation rules. By setting specific time frames and ensuring the door sensor was correctly calibrated, I was able to achieve the desired behavior. I also discovered that integrating multiple devices required careful setup to ensure smooth communication between them.Now, I’m excited to say that the system works beautifully! It’s not only convenient but also helps me save on energy costs. Plus, it adds a touch of modernity to my bathroom.I’d love to hear from others who have tackled similar projects. What challenges did you face? What tips can you share for setting up automated lighting systems? Let’s continue to learn and grow together in the smart home community!
