I’ve been experimenting with setting up my smart lighting to automatically turn on at sunset and shut off at 11 pm. While it sounds straightforward, I initially struggled with figuring out the best approach. After some research and trial and error, I found that creating two separate automations was the most reliable solution for my setup.
For the sunrise trigger, I used my smart lighting platform’s built-in sunset detection feature. This automatically activates the lights when the sun sets, ensuring a seamless transition from daylight to artificial lighting. It’s been a game-changer for maintaining a consistent evening routine without manually adjusting the lights.
For the bedtime trigger, I set up a separate automation to turn the lights off at 11 pm. This ensures that I don’t forget to turn them off late at night, which has been a common issue for me. The integration with my smart hub has made this process incredibly smooth, and I’ve noticed a significant reduction in energy usage as a result.
One thing I learned during this process is the importance of testing each automation separately before combining them. This helped me identify any potential conflicts or timing issues early on. I also recommend reviewing the automation settings periodically to ensure everything continues to work as expected.
If anyone else is looking to set up similar lighting automation, I’d highly recommend starting with separate triggers for each action. It might seem a bit more involved initially, but it provides greater control and reliability in the long run. Happy automating! ![]()
