Smart Lighting Automation with Motion and Garage Door Sensors
Hey everyone, I wanted to share my experience setting up a smart lighting automation system using motion sensors and garage door sensors. I’ve been working on this for a while and thought it might be helpful for others who are looking to do something similar.
The Goal:
I wanted to create a system where my garage lights turn on automatically in two specific scenarios:
  1. When motion is detected and the garage door is closed.
  2. When the garage door is open, especially during sunset and sunrise hours.
The Challenge:
Initially, I tried using the Motion and Lightning app to set this up. However, I ran into an issue where I couldn’t find a way to use an OR condition within the app. This meant I couldn’t combine the two triggers (motion detection and garage door status) into a single automation rule. After some research, I discovered that the Rule Machine was the perfect tool for this job!
The Solution:
Here’s how I set it up using the Rule Machine:
  1. Trigger:
    • Garage Door Open: I set up a trigger that activates when the garage door is opened.
    • Motion Detected: I also set up a trigger that activates when motion is detected in the garage area.
  2. Conditions:
    • Time of Day: I added a condition to check if the current time falls between sunset and sunrise. This ensures that the lights only turn on during these hours when the garage door is open.
    • Garage Door Status: I included a condition to check if the garage door is closed when motion is detected.
  3. Actions:
    • Turn On Lights: If either of the triggers is activated and the conditions are met, the garage lights turn on.
    • Turn Off Lights: I also set up a rule to turn off the lights after a certain period of inactivity to save energy.
Tips for Others:
  • Test in Different Conditions: Before finalizing your setup, test the automation in different scenarios to ensure it works as expected.
  • Use the Rule Machine for Complex Logic: If the built-in apps don’t offer the flexibility you need, don’t hesitate to dive into the Rule Machine. It’s incredibly powerful once you get the hang of it.
  • Consider Sunset and Sunrise Times: Using dynamic time settings based on sunrise and sunset can make your automation more efficient and user-friendly.
Final Thoughts:
This setup has been working perfectly for me, and I love how it enhances my daily routine. Whether I’m coming home late at night or just opening the garage to grab something, the lights are always there when I need them. I’d love to hear how others have tackled similar projects or if anyone has tips for improving this setup further!
Cheers,
