I’ve been working on setting up a smart lighting system in my home, and I wanted to share my journey and some tips that might help others. My goal was to create an automation that turns on the lights in the corridor when motion is detected, but only if the room isn’t already bright enough. This way, the lights don’t come on unnecessarily during the day or if the room is already well-lit.
I started by using Node-RED to design the automation. I connected a binary sensor for motion detection and integrated it with my Philips Hue lights. The challenge was to include the illuminance data from the Hue sensor to ensure the lights only activate when the room is darker than a certain threshold, say 50 lux. After some trial and error, I managed to set it up so that the lights turn on at full brightness during the day and at a lower setting in the evening, using a time-range switch for consistency.
One thing I learned is the importance of testing each component individually before integrating them into a full automation. For example, ensuring the motion sensor accurately detects movement and the illuminance sensor provides reliable readings was crucial. I also found that adding delays between actions helped prevent issues where the system might not have enough time to process each command before moving on to the next.
If anyone has tips on optimizing such automations or suggestions for improving this setup, I’d love to hear them! It’s been a rewarding project, and I’m excited to see how I can expand this system to other areas of my home.
