Smart Lighting Automation with WLED and Garage Door Status
Hey everyone, I’m diving into the world of smart lighting automation with my WLED strips and garage door. I want to create a system where the lights change based on whether the garage door is open or closed. Let me walk you through my journey so far!
The Goal:
I have these WLED strips installed in my garage, and I want them to switch between different preset modes depending on the garage door’s status. For example, when the door is opening, the lights could pulse red, and when it’s fully open, they switch to a steady green. The challenge is getting the automation to work seamlessly with the door’s sensor and the WLED controller.
The Setup:
I’m using Home Assistant for this project. The garage door is connected via a binary sensor, and I have a select entity set up to manage the WLED preset modes. I’ve written a basic automation script, but it’s not quite hitting the mark yet. Here’s what I have so far:
yaml
alias: Garage Light Automation
description: Change WLED preset based on garage door status
trigger:
  • platform: state
    entity_id: binary_sensor.garage_door
    to: ‘on’
    action:
  • choose:
    • conditions:
      sequence:
      • service: select.select_option
        data:
        option: Transition
        entity_id: select.wled_preset
      • delay: seconds: 2
        data:
        option: Open
      • delay: seconds: 5
        data:
        option: Transition
The Issues:
  1. Delays Not Working as Expected: The delays between preset changes aren’t consistent. Sometimes the lights switch too quickly, and other times there’s a lag.
  2. State Transitions: The automation isn’t handling the transition states properly. I want the lights to smoothly transition between modes, but it’s more of a jarring switch right now.
  3. Sensor Feedback: The binary sensor for the garage door is reliable, but I’m not sure if it’s providing the necessary feedback for the automation to function correctly.
What I’m Hoping to Achieve:
I want the lights to act as a visual indicator of the garage door’s status. When the door is opening or closing, the lights should pulse in a transition color (like red). When it’s fully open, they should switch to a steady color (like green). This would not only be functional but also add a nice aesthetic touch to my garage.
Where I Need Help:
  1. Automation Script Fine-Tuning: I need help tweaking the automation script to handle delays and state transitions more effectively.
  2. Sensor Integration: I’m not entirely sure if the binary sensor is configured correctly. Any tips on ensuring it provides accurate and timely feedback would be appreciated.
  3. WLED Preset Management: I’m using a select entity to manage the WLED presets, but I’m open to suggestions on whether there’s a more efficient way to handle this.
Why I’m Excited:
This project is a great way to combine my love for DIY home automation with some creative lighting effects. Getting this to work would not only be a practical solution but also a fun way to enhance my garage’s functionality.
If anyone has experience with similar setups or can spot where I might be going wrong, I’d be thrilled to hear from you! Let’s make this garage lighting automation project a success!
Cheers,
