Smart Lighting Automation with Wyze Bulbs
I’ve been experimenting with Wyze bulbs and their integration with my smart home setup. One thing I’ve been curious about is setting up a motion sensor and window sensor to trigger the Wyze bulbs. After some research and tinkering, I found that it’s actually quite straightforward! Here’s how I did it:
  1. Setup: I paired a Wyze motion sensor with my Wyze bulbs. The idea was simple—when the motion sensor detects movement or the window sensor is triggered, the lights should turn on.
  2. Automation Rules: Using the Wyze app, I created a rule that links the sensors to the bulbs. It took a bit of trial and error, but once configured, it worked seamlessly!
  3. Testing: I tested the setup by opening the window and moving around the room. The lights turned on instantly, and I could adjust the brightness using the app. It’s been a game-changer for my home security and convenience.
If anyone else is looking to do something similar, I’d recommend checking out the Wyze app’s automation features. They’re user-friendly and powerful enough for most setups. Let me know if you have any questions or tips to share!
Cheers, [Your Name]
