Recently, I’ve been diving into the world of smart lighting automation, and I must say, it’s been an incredibly rewarding experience. I decided to go with Xiaomi devices for my setup, specifically the Yeelight RGBW bulbs and the Mi Smart Wall Switches. The integration with Home Assistant has been seamless, and I’m thrilled with how everything is coming together.
My Journey So Far
I started by setting up the bulbs using the Tuya Local integration. Initially, I was a bit confused about how to configure the dimmer switches properly, but after some research and trial and error, I managed to get everything working smoothly. The key was ensuring that the devices were correctly identified in the Tuya app and then synced with Home Assistant.
A Little Trick I Discovered
One thing I wanted to achieve was having the bathroom lights automatically adjust their brightness based on the time of day. I found that using the input_boolean entity was perfect for this. I set up an automation where, in the morning, the lights brighten to 80% and dim to 30% in the evening. This has made my mornings much more pleasant!
alias: Bathroom Light Automation
trigger:
- platform: time
hours: 7
minutes: 0 - platform: time
hours: 22
minutes: 0
action: - service: light.turn_on
data:
entity_id: light.bathroom_ceiling
brightness_pct: 80 - service: light.turn_on
data:
brightness_pct: 30
A Little Story
I remember the first time I walked into my bathroom in the morning and saw the lights automatically brighten—it was like magic! It’s these small moments that really make you appreciate the effort you’ve put into setting up your smart home. It’s not just about convenience; it’s about enhancing your daily routine.
Tips for Others
If you’re just starting out, I’d recommend taking your time to understand the configuration options in the Tuya app. Also, don’t hesitate to explore the developer tools in Home Assistant; they’re incredibly helpful for troubleshooting and fine-tuning your automations.
To those who might be struggling with similar setups, remember that every challenge is an opportunity to learn something new. The community here is amazing, and I’ve found a lot of support through forums and documentation.
Let me know if you’ve got any questions or tips of your own—I’m always happy to help out!
Cheers,
