Smart Lighting Hack: Monitoring Washer Status with Color-Changing Bulbs
I recently stumbled upon an ingenious way to use my smart lighting setup to monitor the status of my washer without constantly checking the machine. Let me share my experience and the fun process of setting it up! The Problem: My washing machine is in a utility room with no window, making it hard to check its status without physically going there. I wanted a way to know when the cycle started, paused, or finished—preferably without having to install a new device or sensor. The Solution: I have a set of color-changing smart bulbs in my hallway. After some research, I realized I could use one of them to indicate the washer’s status. Here’s how I set it up: 1. Identify the Trigger: I used the existing motion sensor in my utility room. When the washer door opens, it triggers the motion sensor. 2. Create a Rule: Using my smart home app, I created a rule that changes the bulb’s color based on the washer’s status: - Blue: Washer is running. - Yellow: Washer has paused (e.g., during a cycle). - Green: Washer has finished. 3. Adjust for Accuracy: Initially, the motion sensor was too sensitive and triggered false readings. I adjusted its sensitivity settings and positioned it slightly higher to avoid detecting minor vibrations. The Outcome: This setup has been a game-changer! Now, I can glance at the hallway bulb and immediately know the washer’s status. It’s a simple yet effective use of existing smart home technology. Tips for Others: - Start Small: Begin with one sensor or bulb and gradually expand. - Experiment with Colors: Use colors that are intuitive for you (e.g., red for error, green for completion). - Fine-Tune Sensors: Don’t be afraid to adjust settings for better accuracy. This project has taught me the value of creative thinking and how existing smart home devices can be repurposed for new uses. I’d love to hear how others have hacked their systems for unique purposes! Happy smart home tinkering! :rocket::bulb:
