Smart Lighting Integration and Controller Usage
I’ve been diving into the world of smart lighting and wanted to share my experiences and some questions I’ve come across. First off, I recently set up an RGBWW2 controller with a 12-meter white LED strip, totaling 120W. The controller is rated for 90W per channel, so I’m curious if there’s a way to split the output across two channels (60W each) and control them simultaneously through the app as if they were a single channel. Would this require a second controller or can I manage it with the existing setup? I’m looking for advice on optimizing my setup without overspending.
Another topic I’m exploring is integrating motion detectors with dimmer lamps. I’ve noticed that while the motion detector activates the light, it often flickers or turns off unexpectedly, especially during periods of inactivity. I’m wondering if there are settings or adjustments I can make to ensure the light remains on consistently when motion is detected. Any tips or experiences would be greatly appreciated!
On the automation front, I’ve encountered an issue where my system isn’t updating sensor data correctly. It seems like the system isn’t recognizing changes made outside of Home Assistant, which is a bit frustrating. I’m curious if there are any API calls or scripts that can force the system to refresh its states without having to restart the entire platform. This would save a lot of time and ensure smoother operations.
Lastly, I’m exploring ways to integrate existing non-smart LED strips into my smart home ecosystem. I’ve had some success with DIY solutions using ESP8266 modules, but I’m looking for more user-friendly, plug-and-play options that are compatible with Home Assistant. If anyone has recommendations or experiences with specific products, I’d love to hear about them!
Overall, I’m really enjoying the journey of enhancing my home’s automation, but there are definitely some hurdles to overcome. I’m excited to connect with the community and learn from others’ experiences and solutions.
