After spending several hours trying to integrate my Ikea Tradfri motion sensor and on/off switch into my Home Assistant setup, I wanted to share my journey and the eventual solution I found. My setup includes a TrueNAS server with the Home Assistant plugin, a Conbee II USB coordinator, and the Tradfri devices mentioned. Initially, I faced the issue of the devices not being discovered or paired through the ZHA integration, which was quite frustrating given how smoothly other devices have worked with my system.
I started by checking the functionality of the Conbee II USB stick through Windows and setting up a temporary network with the Tradfri motion sensor to ensure it was working. The logs indicated that devices were being discovered but not successfully joined to the network. This led me to experiment with different configurations, including attempting to connect the devices to an old Windows-powered network, hoping it might help ZHA recognize them. While this was a long shot, it was worth a try given the time I had already invested.
After several failed attempts, I decided to reset the Conbee II coordinator and start fresh. This involved deleting all existing Zigbee devices from my Home Assistant configuration and reinitializing the network. To my relief, the Tradfri devices were finally recognized and paired without further issues. I realized that sometimes a clean slate is the best approach, especially when dealing with complex mesh networks like Zigbee.
For anyone else facing similar challenges, I recommend thoroughly checking the coordinator’s functionality, ensuring all devices are in range, and not hesitating to reset and restart the network if initial attempts fail. It’s also crucial to review the logs for any clues, as they can provide valuable insights into what’s going wrong. While the process was time-consuming, it taught me a lot about troubleshooting Zigbee devices and the importance of patience in smart home setups.
If you have any additional tips or experiences with integrating Tradfri devices into Home Assistant, I’d love to hear them! Let’s continue to support each other in building seamless smart home ecosystems.
