Smart Lighting Issue Using More Than 8 Open/Close Sensors As Triggers
I wonder if someone can see if they have this issue with Smart Lighting. What I tried to do was turn on a 2 switches (which turn on recording for my indoor cameras) if any of my 15 Open/Close sensors opened while I was away or sleeping. What I found is that if I select more than 8 sensors as triggers, then Smart Lighting will not display the second screen where you can change the rule name and save. It just hangs with a blank screen. It’s not related to any individual sensor as I checked different combinations of sensors with the same results. It seems that I am capped at 8 individual Open/Close triggers. As an experiment, I tried using 10 Motion Sensors to see if the limiting behavior was exhibited with all triggers. It wasn’t. I was able to select all 10 of my Motion Sensors so it doesn’t appear to be a hard limit on the number of triggers allowed. I can use WebCoRe to accomplish what I want but, I am curious if others see this behavior and if so, is this a bug or is it done on purpose in Smart Lighting.
