Smart Lighting Setup: MQTT Dimmer and Color Temperature Integration
After spending several weeks setting up my smart home, I wanted to share my experience with integrating a ceiling light using Tasmota and MQTT with OpenHAB. This journey taught me a lot about MQTT configurations and how to bridge different systems effectively.
Initially, I faced challenges with the color temperature integration. The range for color temperature (153-500) didn’t map directly to the dimmer slider in OpenHAB, causing the slider to display incorrectly. After some research and testing, I realized that specifying the min and max values in the MQTT channel was crucial. Here’s how I configured it:
plaintext
Type dimmer : colortemp “Color Temp” [ stateTopic=“stat/utorch2/RESULT”, commandTopic=“cmnd/utorch2/CT”, transformationPattern=“REGEX:(.CT.)∩JSONPATH:$.CT”, min=153, max=500 ]
This setup ensures that the slider maps correctly from 0-100 to the actual CT range. However, I noticed that the slider’s visual feedback wasn’t updating as expected. After some troubleshooting, I discovered that the issue was with how the UI handled the range mapping. To resolve this, I adjusted the item definition to ensure the slider’s scale matched the CT range.
One of the most rewarding parts of this project was seeing how seamlessly the brightness and color temperature could be controlled through Home Assistant. It’s amazing how a few lines of configuration can transform a basic setup into a fully functional smart lighting system.
I’d love to hear from others who have tackled similar projects or have tips for optimizing MQTT configurations. Happy tinkering! :rocket:
