Hello everyone! I wanted to share my recent experience setting up a smart lighting system using ESPHome and WS2812B pixels. It’s been a fantastic journey, and I’m thrilled with the results!
I started by purchasing a TTGo camera board and some WS2812B pixels. My goal was to create a customizable lighting setup that I could control through Home Assistant. After some research, I decided to use ESPHome for its simplicity and integration with Home Assistant.
The setup process wasn’t without its challenges. Initially, I struggled with configuring the pixels correctly. I tried several methods, including using neopixelbus and fastled_clockless, but nothing worked as smoothly as I hoped. However, after some trial and error, I found the perfect configuration that allowed me to control the pixels using GRB color settings.
One of the most rewarding parts of this project was seeing the pixels light up for the first time. It was like magic! I could control them through Home Assistant, adjust the brightness, and even change the color temperature. The flexibility of ESPHome made it easy to integrate this setup into my existing smart home ecosystem.
Here are a few tips I learned along the way:
- Start small: Begin with a single pixel to test your configuration before adding more.
- Check your connections: Ensure your pixels are properly connected to avoid any unexpected behavior.
- Experiment with different configurations: Don’t be afraid to try different settings until you find what works best for your setup.
I’m really happy with how this project turned out. It’s not only functional but also adds a touch of elegance to my home. If you’re considering a similar setup, I highly recommend giving ESPHome and WS2812B pixels a try!
Thanks for reading, and happy tinkering! ![]()
