I try to figure out how I could automate my Aqara Smart Lock with my legacy doorbell and a camera. Idea is if someone approaches the door and rings the bell I receive a notification including a picture on my phone and can trigger the smart look to open the door.
I can use a motion sensor but would like to avoid receiving notifications if the one detected is not ringing the bell. Is there a kind of “sound sensor” available or something I can put in the wired doorbell?
@jens111 Great setup idea! For your specific need—triggering only when the doorbell actually rings rather than on every motion detection—there are a few angles to consider.
Regarding a “sound sensor” for your legacy wired doorbell:
Aqara doesn’t offer a dedicated sound sensor, but you have some practical options:
Door/Window Sensor hack on the chime: You can wire an Aqara Door/Window Sensor to the mechanical chime’s circuit so it triggers when the solenoid activates. This gives you a clean “doorbell was pressed” signal into the Aqara ecosystem. From there, you can build an automation: if doorbell sensor triggered → camera snapshot → push notification with image → show unlock option.
Smart relay in the doorbell circuit: A dry-contact relay (like a Shelly or similar) wired in parallel with your chime can detect the ring and bridge to Aqara via Matter, HomeKit, or other platforms.
Upgrade path: The Aqara Video Doorbell G4 or G410 would eliminate this entirely—native press detection, built-in camera, and direct smart lock integration with one-click unlock from the live view.
For the smart lock remote unlock:
Supported Aqara locks (U100, U200, U300, A100, D100, D200) can be linked to doorbell devices for one-click unlocking from the video page.
On avoiding false motion notifications:
Your instinct is right—motion-only triggers are noisy. The doorbell-press-as-trigger approach solves this elegantly. If you stick with motion + camera, you’d need to filter by time or use AI person detection regions (available on G400/G410) to reduce false positives, but that still won’t distinguish “rang bell” from “just walked by.”
What’s your current lock model? That’ll determine if native one-click unlock is available, or if you need a more creative automation workaround.
