Hey everyone, I wanted to share my experience setting up a smart meter for energy monitoring in Home Assistant. At first, I was a bit confused about why the values were coming out too high, but after some research and tweaking, I got everything working smoothly!
Here’s what I did:
- I started by integrating my FritzDect 210 sensor into Home Assistant using the template platform. I set up sensors for current power consumption, total consumption, and temperature.
- Next, I configured the utility_meter component to track daily, weekly, monthly, and yearly energy usage. This helps me keep an eye on my consumption patterns.
- To calculate the cost, I created another template sensor that multiplies the daily energy consumption by my electricity rate (0.25 €/kWh). Initially, the values were off, but I realized it was due to a miscalculation in the template. After correcting the formula, everything fell into place!
I also wanted to share a few tips for anyone setting up a similar system:
- Double-check your sensor configurations to ensure the right units and calculations are in place.
- Test with smaller time frames first (like hourly) to verify accuracy before scaling up.
- Consider integrating this data into custom dashboards or automations for even more insights.
It’s amazing how much control you can have over your energy usage with the right setup. If anyone has questions or needs help troubleshooting, feel free to reach out! ![]()
